Hi everyone
I am looking for any assistance and advice anyone may want to pass on. I'm doing a project and will explain what I want to achieve below, but I am totally new electronics so dont even know where to start. Ideally I would like someone to be able to offer a solution with drawings, components and the knowledge to help me to understand what I need to do.
After some basic electronics reading I see this is a huge and complex field and just dont have the time to delve into this interesting but equally scary subject.
The project.
I would like to mount a series of LED's inline along 8 seperate paths. Each path is different in length. Each LED will sit approximately 15mm apart from center to center and therefore each path will have more or less LED's along each path.
Each of these 8 paths start from the same point and I want them to start at the same time but take individual times to complete their path which I set to between 8 minutes and 45 minutes.
Each path must stay lit until the longest and last path has completed then the complete circuit is repeated continously.
I would like to use 3mm LED's and a 9V battery.
All of this is mounted on a piece of 6mm acrylic measuring 1200mm x 700mm.
The LED's and electronics need to be mounted on the backside of the acrylic.
On the front of the acrylic I have slotted the paths and the course of the river Thames in London. The paths represent my usual cycle routes over a seven day period which I repeat weekly. As it is a contemporary and minimal map the river Thames scribed on the acrylic hints at the map of London.
I will submit some jpegs in cad view so that everyone can physically see what I am doing.
Many thanks to everyone viewing this..
The project.
