New Power Suppy - Does this sound rightt??
Discussion in 'General Electronics Chat' started by spinnaker, Jan 21, 2013.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,062
    1,159
    I just got in this new power supply.
    http://www.circuitspecialists.com/bench-power-supply-csi3303s.html
    Instructions say to sort "a wire" between terminals and set the max current.
    Does this sound right? I would assume that I would need the appropriate size wire for higher currents?
    Do most lower end bench power supplies only have a resolution to hundredths of an amp and volt?
  2. Ron H
    Apr 14, 2005
    7,050
    657
  3. spinnaker
    Oct 29, 2009
    5,062
    1,159
    I was thinking of making a shorting bar out of a piece of aluminum. I think I have seen this on other power supplies?
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Applying a short between the output terminals allows you to set a level of current that will you desire to protect any circuits you are testing. It doesn't take a very big wire to carry the full output of your power supply. (24AWG will carry 3.5 amps all day long)
    Many entry level bench supplies don't even have digital meters and the analog meters are hard to interpret .01 amp. Unless you are doing very high accuracy experimenting, what you have is, as Tony the Tiger says, "GREAT!"
  5. Ron H
    Apr 14, 2005
    7,050
    657
    If you're just using it to set the current limit, you can use anything that won't melt itself or your binding posts.
    A heavy-duty momentary pushbutton on the front panel would have been handy.
  6. GopherT
    Nov 23, 2012
    6,297
    4,019
    I think you set current limits with voltage set to zero. At zero volts and shorted leads, the unit goes into "program mode" so you can set max current. I don't think current even flows, you are only setting the limit and using the current meter to view your set point.
  7. spinnaker
    Oct 29, 2009
    5,062
    1,159
    Institutions say to set voltage to 3-5V.
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    Is this for calibration or general use?
    In general use, I usually set the voltage low, then increase current, if the voltage keeps climbing beyond what is expected, I look for the problem.
    For calibration of the display, any wire that can handle ~5A for a minute or two would work. So, 22 ga or larger.
  9. ErnieM
    Apr 24, 2011
    7,433
    1,623
    If the wire you are using to connect the supply to your device cannot handle the current to do this test... then you've been using the wrong wire all along.
