Hi...
I have a new OpAmp circuit to analyse and part of the analysis is already done!
It is a "Widow Detector" and we have the circuit split in 3 separate blocks. Block 1 which is a Schimtt Trigger, Block 2 which is an Integrator and the 3rd one I'm still not sure what it is!
I think it is at least an Half-Wave rectifier but it has probably some other function that I don't know!
I need some help to identify it and give an explanation of the role of this block on the whole circuit!
I have tried to simulate Block 3 on LTSpice, first using a sine wave and I tried with a triangular wave. But for the triangular wave I was not able to setup the input voltage source the way I wanted as it is in the attached file!
I have also tried to use discrete values (see picture below) on the right voltage source and tried to use the directive ".param" to make things a bit more simple to read but I couldn't! I can' figure out what's wrong with the parameters in the simulation!
http://i.imgur.com/kDKuvLz.png
