New One.
Discussion in 'General Electronics Chat' started by atotoarere, Nov 29, 2006.
  1. atotoarere
    Nov 27, 2006
    8
    P/z, Can Anybody Help Me Out Of This ?
    (1) Advantage Of 110 Voltage Over 240 Voltage.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. kc8ljh
    Member
    Nov 25, 2006
    15
    I agree with papabravo
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Being someone who has generally only dealt with small scale voltages and currents I will ask the question: Is there an advantage of 110V over 240V? (Other than Papabravo's reason!)
    Transmission requires higher voltages to reduce the effect of I^2*R losses, so at the end user there is a requirement of larger transformers to step the voltage down; extra cost, space etc...
    Dave
  5. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    230 uses much lighter (and cheaper) cable.
    Not sure what you 110 volt guys use, but we generally use 1.5mm - 2.5mm (TPS) for plug circuits, and 1mm - 1.5 mm for lighting circuits in home wiring.
