New LEDs from much lower voltage !
bertus
Joined Apr 5, 2008
22,278
The "leds" will have some electronics in the base to work on the large voltage range.
This could be a buck/boost circuit.
Bertus
#12
Joined Nov 30, 2010
18,224
I have a Joule Thief flashlight (white LED) in my pocket that will run from a single AA battery. It must have .6 volts to start but it will suck the battery down to 0.1 volt if you accidentally leave it on.
These bulbs that you pointed out will make these flashlights cheaper and smaller because the Mfg. will not need to dedicate half an inch to building the oscillator circuit into the flashlight.
