new in embedded system
Discussion in 'Embedded Systems and Microcontrollers' started by vead, Apr 4, 2012.
  1. vead
    Nov 24, 2011
    621
    8
    hello
    i am vead. i am just starting to learn c programming for embedded system
    please anyone tell me which is common step in c programming for microcontroller
    thanks
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    Get a C compiler for your target processor.
  3. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    If ti's PIC you're getting into, Sourceboost has a free IDE and ANSI 'C' compiler that will support 12, 16 and 18 series chips. There are some limitations to the free version, but it's not expensive to buy if you exceed those limitations.
  4. RiJoRI
    Aug 15, 2007
    536
    26
    The common step for ALL C programmers is frustration!
    Do you know C? Or any other programming language? Do you know about microcontrollers?
    Also, as BillO hinted, which microcontroller are you planning to use?
    Are you attending a class, or do you plan on learning on your own, as I did?
    There are many, many uCs made by many companies. My opinion, if you are learning on your own, is an Arduino board. It's like training wheels on a bicycle. You'll get a (protected) taste of C, after which you can go on to more extensive compilers.
    --Rich
