new here, have project question
Discussion in 'The Projects Forum' started by gixxer50, Aug 17, 2014.
  1. gixxer50
    Aug 17, 2014
    I have a Hertz pressure sensor on my compressor and manual PSI guage, I want to be able to use that sensor to display PSI on a remote mounted LCD display.
    I will need a wireless Hertz receiver and then convert it to digital for the LCD. Any ideas on where to start ?
    Thank you,
    Dave
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    I have never heard of a "Hertz pressure sensor". Can you provide a link to what it is?
  3. gixxer50
    Aug 17, 2014
    I don't have a link and probably worded it wrong, but its an electronic sensor that changes frequency output as pressure builds. I want to convert that frequency to LED display
  4. shteii01
    Feb 19, 2010
    3,516
    515
    Sounds like you need frequency counter.
    Check this short article: http://tushev.org/articles/arduino/item/51-measuring-frequency-with-arduino
    So basically we generally know what you want:
    * Input, frequency.
    * Output, text on lcd
    This is very bare bones. Now you need to put some meat on the bones.
    Input:
    * What is the range of the frequencies? What is the frequency for 0 PSI? What is the frequency for Maximum Pressure? For that matter what is the maximum pressure? 10 PSI? 20 PSI? 50 PSI? 100 PSI? 500 PSI? What is the relationship between pressure and frequency? Is it linear Frequency=m*Pressure+b?
    Output:
    * How big LCD do you want? 2 rows, 20 columns? 4 rows, 20 columns? Bigger than that?
    * What color do you want? Generic green-ish with black text? Blue background with white text, etc.?
    * How do you want to communicate with LCD? Parallel? Serial?
    Here is example of Arduino and LCD interface, this is 4-bit mode Parallel setup. LCD is 2 rows, 16 columns: http://arduino.cc/en/Tutorial/LiquidCrystal
