New Generator 240V out instead of 120V
Discussion in 'General Electronics Chat' started by rplanglois, Jan 19, 2014.
  1. rplanglois
    Dec 11, 2012
    I bought a new gasoline 1300W generator from Canadian Tire. It is is described as 120V only. It has two standard 120V outlets on the front panel and no 240V outlet. When started the front panel meter shows about 240 V and my Fluke meter reads 251V. It should be 120V. Obviously something is wrong. What do my esteemed colleagues think? It destroyed a laptop.
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    What is the Canadian tire cat No?
    Max.
  3. Dr.killjoy
    Apr 28, 2013
    1,208
    157
    Time for warranty repair or fix it urself...
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Take it back to the store.
  5. rplanglois
    Dec 11, 2012
    Sorry, but I don't have that any more. I know it sounds a bit sloppy but this was only started up to make sure it worked and I assumed that the voltage would be more or less OK. I then put it aside and waited for the recent Toronto icestorm. Silly me.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    I've done similar things. Indeed, something is wrong. Call technical support, if the manufacturer has one.
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    Genheads normally have two separate windings, each producing 120V. The windings are connected in series to provide 240V. If you genset has no 240 receptacle and is producing 240V at the 120V receptacles, then it is (obviously) wired wrong. The manufacturer has failed badly, and will be appalled to learn of their error. Contact them, tell them what happened, and I predict they will fall all over themselves to replace your generator and your laptop.
    If it were me, I would be cautious about letting the generator out of my control until it was inspected...but that's just my cynical side coming out.
  8. rplanglois
    Dec 11, 2012
    Looking at the Instruction manual and it has the number 55-03080-0 on it which I believe is the CT number. A quick search at CT and on the net doesn't seem to return much.
  9. MrChips
    Oct 2, 2009
    12,624
    3,451
    What is the brand name and model number?
