New Engineering student needs some help-Solar Powered Water Pump
Discussion in 'The Projects Forum' started by Reigh28, Sep 30, 2016.
  1. Reigh28
    Sep 30, 2016
    Ok everyone, so im a new to engineering and we have to complete a prototype design and I want to build a aquaponics fish farm that is run by solar panels. I have three 7v solar panels that peak at 1.2 watts. I want to wire them in parallel or series whichever will do the trick so a assortment of 9v rechargable battery's with a controller to stop them from overcharging. I need them to to hold enough power to run my water pump at a constant 9 volts for at least 6 hours. How many batteries do I need and are these solar panels sufficient to charge them? If not what would I need? And does anyone have any resources I can look up on how to construct such a battery system? Thanks for any advice and help!
  2. AlbertHall
    Jun 4, 2014
    2,277
    449
    How much current does your pump draw?
  3. Reigh28
    Sep 30, 2016
    It a 7v pump the solar panel came with the pump.
  4. blocco a spirale
    Jun 18, 2008
    1,461
    370
    I believe the question was "how much current does your pump draw?" without this information no one can tell you what size batteries might be required or whether the solar panel can produce enough energy to charge them sufficiently.
  5. ICCircuitman
    Feb 22, 2015
    It sounds like you do not have the electrical specs on the pump. Have you considered determining your pumps current requirements through prototyping ? A bench power supply with current limiting capabilities and a multimeter can help you determine how much input power will be required to make the pump work satisfactory. With that testing completed your design requirements may change from your findings. I have always found it beneficial to test my substems for proper operation and then again when the subsystems are integrated into the final product. Hope these ideas help!
  6. ci139
    Member
    Jul 11, 2016
    341
    39
  7. wayneh
    Sep 9, 2010
    12,391
    3,246
    One watt of power won't move much water. Before we talk about solving the electrical problems, can you verify that your system is so small that 1W of pump power is even useful? Even an aerator will likely need more power than that. My cats have a water fountain with a little pump to keep the water moving. I'll bet even that little trickle uses more than 1W.
  8. AlbertHall
    Jun 4, 2014
    2,277
    449
    There are three panels so that's 3.6W but it's still not much.
