New DTMF based project for advanced communications
Discussion in 'The Projects Forum' started by Elijah Lingbanan, Jul 29, 2015.
  1. Elijah Lingbanan
    Jul 28, 2015
    6
    Hi, i want to use DTMF tones to be usable in a new way and also in communications application. Can you give me some idea that i can make as a project that is cost-effective? thanks.
  2. Ramussons
    May 3, 2013
    562
    92
    Telecommand
    Remote control thru' phone lines (wired and wireless)
    incidentally, both are not new. :rolleyes:
  3. blocco a spirale
    Jun 18, 2008
    1,461
    370
    You're over half a century behind the curve.
  4. DickCappels
    Aug 21, 2008
    2,779
    674
    Remote control seems like an obvious choice. You could command various devices be switched on or off or setting such as a thermostat setting can be changed by using various codes.
  5. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    Communications will be dissappinting.
    It takes a fair time to decode each tone with hardware,
    and I imagine software doing it quicker to be error prone.
    I audio coupled a DTMF synth with a Motorola decoder chip with opamp driven mic.
