I have a new problem after I discovered the green raster transistor on the neckboard was loose at the solder joints. After that was fixed and picture has normal colors, I poked around the neck board with my mulitmeter, I took voltage measurements of the 3 raster transistor's emitter, collector, base, then I measure the 4 wires going into the funnel end of the deflection yoke, one of the wires connector when touched by probe made a staticky sound and multimeter reads overload.. I don't know if that was the cause but moments later when I turned around to check the picture it became black and white (or should I say some 2 toned colors). I still have color because turning the pots on the neckboard changes the 2 tones into 2 tones of green, blue, red respectively. And I have color on the on screen display text characters.
My measurements at emitter, collector, base are 13Vdc, 150Vdc, 13Vdc for all three colors. They are hot to touch. I think that means they are in saturation all the time.. maybe they are fried.. Do you know what voltage should the base have normally? I think 13V reading is too huge isn't it? Thus rgb colors in picture are always in max.. The raster transistors are Toshiba C2068
http://www.alldatasheet.com/datasheet-pdf/pdf/108529/TOSHIBA/2SC2068.html
Or the chroma chip is toast? The chroma chip is TA... in photo attached. Please advice. Thank you!!
