new circuit without power to light bulb
Discussion in 'The Projects Forum' started by william Kinser, Aug 13, 2008.
  1. william Kinser
    Aug 13, 2008
    new circuit. all outlets check out with circuit tester but not enough power at outlet to light a light bulb.
  2. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Thanks for the update.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings kinser,
    Do you have a specific question? It is unclear from your initial post what you are asking.
    hgmjr
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Take a known-working lamp from an existing circuit, and move it to the new circuit. If it doesn't light, plug it back into the existing circuit and make sure that it's still lighting up there.
    If it was lit before in the old circuit, doesn't light in the new circuit, but still lights in the old circuit after the test, then call the electrican who installed the new circuit and have him repair it.
    Or is this a "do it yourself" thing?
