Never Complain About Soldering SMD's Again
Discussion in 'Off-Topic' started by jpanhalt, Oct 10, 2016.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    cmartinez likes this.
  2. joeyd999
    Jun 6, 2011
    2,756
    2,920
    nsaspook likes this.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I agree, it is more a matter of desire rather than ability. I have switched to solderable breadboards and commercial PCB's for more "final" designs too.
    Still, the workmanship is to be admired.
    John
  4. ronv
    Nov 12, 2008
    3,393
    1,451
    Had a tech do that once for us. It was on a compatible processor with a different pin out from the previous one. As a matter of fact he did it twice.
    Latter found out there was a code command that was different that we didn't know about until later so we couldn't get it to work at the time. By the time we found it the guy was gone. Probably a good thing as I'm sure he would have killed me.:D
    He did it with 30awg wire wrap wire.
  5. ErnieM
    Apr 24, 2011
    7,436
    1,625
    At lease he's using the prototype wire where the insulation melts away when heated. It just looks like magnet wire where you have to mechanically strip the varnish.
    While I admire the work I far prefer using adapter boards and ez to strip 30AWG wire wrap wire.
  6. #12
    Nov 30, 2010
    16,665
    7,310
    Run 6 wires down a single hole?:eek:
    All the same color?
    My eyes went past that stage a long time ago!
    Seriously. One person asked me why I didn't make all my wires the same color and I answered, "I used 56 different color and stripe combinations, and you can't find ground. How lost would you be if they were all black?"
    So this Japanese guy uses all copper colored?
    I might have been able to handle that 30 years ago.:(
  7. GopherT
    Nov 23, 2012
    6,303
    4,021
    If one takes the time to learn the technique of soldering soic-sized components, it is easy. Especially since there are no holes to drill - a complete step avoided. I prefer soic.
    On the other hand, saying Never Complain, on the basis that someone else has gone through worse is a weird concept. I'm still going to swear and yell if I hit my thumb with a hammer even though other have done it worse - see YouTube for examples.
    #12 likes this.
