Neutron generations
Discussion in 'Physics' started by sytem_recon, Jun 14, 2010.
  1. sytem_recon
    Thread Starter Active Member
    Apr 21, 2009
    52
    How to calculate the no of neutron generations in a nuclear device?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  3. sytem_recon
    Apr 21, 2009
    52
    The web site has no idea of generations calculation
  4. someonesdad
    Jul 7, 2009
    1,585
    141
    Your question is about as specific as "how long is a piece of rope?"
    I suggest you consult a beginning nuclear physics text, as it will have some of the basics. It will also, of course, have references to more of the literature. You can also consult books on nuclear engineering, which will have empirically-derived formulas. If you want to calculate things from first principles, read up on stuff done on the Manhattan project during WW2 and after. You'll get into all kinds of neat stuff like Monte Carlo models, diffusion problems, cross sections, etc. I believe the mathematician Ulam did quite a bit on the problem (along with many others).
  5. retched
    Dec 5, 2009
    5,201
    313
    I would use a Neutron Counter, then do a before and after calculation. ;)
    But then again, subtraction has always been my strong suit. ;)
  6. sytem_recon
    Apr 21, 2009
    52
    Sir someonesdad can you give me the sites or names of Ulam work he did in this field. I searched but i haven't find some one.
  7. someonesdad
    Jul 7, 2009
    1,585
    141
    You might want to go to a library and get some literature searches done in a computerized database. Your librarian will know how to do this stuff.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
