can I taky my 120 v from the line and ground (in home) instead of taking between line and neutral because neutral and line in most case connected together
Absolutely not. Why do you think there are separate neutral and ground wires? It's to protect you if there's a short between an appliance hot wire and its case, which is connected to the ground. If you use the ground to carry current then an accidental interruption in that ground wire will cause everything connected to the ground to suddenly have mains voltage appear on their cases. Definitely a no-no.can I taky my 120 v from the line and ground (in home) instead of taking between line and neutral because neutral and line in most case connected together
by Jake Hertz
by Jeff Child
by Jake Hertz
