network pakager
Discussion in 'Homework Help' started by waleedsial, May 4, 2012.
  1. waleedsial
    May 4, 2012
    5
    Network Packager
    Problem
    There is an Ethernet card that lacks checksum calculation and you are required to add this functionality. The Ethernet card is to get 4 bits at a time from the CPU and collect until it has 16 bits. Then it adds the 4, 4 bit numbers and uses the lower four bits for checksum, thus making a total of 20 bits. It then sends one bit with every clock cycle until the buffer is empty. During transmission it does not receive new data from the CPU.
    Input
    Clock Pulse CP
    Input Available IA
    Data D0…D3
    Output
    Output Available OA
    Output Data OD
  2. waleedsial
    May 4, 2012
    5
    please help me....
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Way too little information. Make and model of the network card, how you are using it.
    I buy network cards for $2-10 each. At that price if it doesn't work it isn't worth messing with.
  4. waleedsial
    May 4, 2012
    5
    ok but i have made a high level diagram
    can you check it and let me know whether it is correct or not?
  5. #12
    Nov 30, 2010
    16,665
    7,310
    This sounds like school work. Is this school work?
  6. waleedsial
    May 4, 2012
    5
    yeah i have to give a presentation tomorow,than a question answer session and than implementation
  7. waleedsial
    May 4, 2012
    5
    any kind of help?
