network packager
Discussion in 'Homework Help' started by mudassaralvi, Apr 28, 2010.
  1. mudassaralvi
    Apr 28, 2010
    Network Packager
    Problem
    There is an Ethernet card that lacks checksum calculation and you are required to add this functionality. The Ethernet card is to get 4 bits at a time from the CPU and collect until it has 16 bits. Then it adds the 4, 4 bit numbers and uses the lower four bits for checksum, thus making a total of 20 bits. It then sends one bit with every clock cycle until the buffer is empty. During transmission it does not receive new data from the CPU.
    Input
    Clock Pulse CP
    Input Available IA
    Data D0…D3
    Output
    Output Available OA
    Output Data OD
    any one can sketch a block diagram...help
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Arte you sure you want a block diagram? Something more like a flowchart seems more useful. What have you tried so far?
  3. mudassaralvi
    Apr 28, 2010
    the flow chart will also do...
  4. retched
    Dec 5, 2009
    5,201
    313
    I agree. It will help.
    Why dont you try to put a flow chart together and we'll go from there.
