I have a bunch of older novell software. I was hoping to install netware on something to just mess with, but the first try was with a Compaq deskpro EN, after copying cd to a hard drive then making that a slave disk. I booted dos, launched installer, got a bunch of screens, I got to driver install part, and it was requiring nic driver, IDE driver. I looked online and there is nothing available for the devices for NetWare. I decided it may work in virtual box, but not sure that be any better as emulated hardware is also fairly new. I took the dos floppy, made .img of it, mounted as floppy in vbox, boots fine.
Now I need to get to CD to install NetWare. I tried assigning host drive direct, and making iso, and mapping to it. Dos will not recognize as even exists. I tried changing drives through hole alphabet, and nothing. Near as I can tell it is like MSdos with letter mappings, not /dev like Linux. I'm not exactly sure what issue is. I thought when mapped drive direct the letter from host would carry to guest, but don't look like it. I guess could be driver also, but I'm leaning towards letter not assigned.
Any way in vbox to manually assign letter, or any other ideas?
I'm new to Novell so I may just be missing something, but even help isn't giving me much clues in DOS.
I have an old power edge 2300 server like 300MHZ from mid 90's I think that may work since older. Big system to keep around though just for messing with netware, so much prefer VM.
