Net Voltage in inductor cicuit
Discussion in 'General Electronics Chat' started by Muhammad AbuBakr, May 20, 2015.
  1. Muhammad AbuBakr
    May 20, 2015
    What is the expression for net voltage in a circuit which has a coil connected in series with battery through a rheostat (so current can be changed)?Where in the circuit is back emf present?
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    The back-emf is generated directly across the coil (i.e between its two terminals) when the current is changed.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    The back emf is developed across the inductor - but you won't generate much emf by varying a rheostat.
    The back emf is produced when lines of magnetic flux surrounding the inductor collapse. This has to happen fairly rapidly to generate much voltage.
  4. Muhammad AbuBakr
    May 20, 2015
    I am fine with that.Get this."If the current decreases the back emf will try to aid the battery"By aiding it means the back emf's polarity will be such that it will try to increase the current in the circuit.Am I right?
  5. Muhammad AbuBakr
    May 20, 2015
  6. ian field
    Oct 27, 2012
    4,459
    792
    The action of an inductor is opposite to that of a capacitor - the capacitor will oppose the voltage change by either charging or discharging, and in so doing taking or giving up current.
    If you vary the current through an inductor with a rheostat, the magnetic lines of flux around the inductor will expand or contract accordingly - but you'd probably need laboratory instruments to record that in action.
  7. crutschow
    Mar 14, 2008
    13,508
    3,384
    Not quite. The induced voltage will be such as to try to keep the current flowing. It will not increase the current.
    An inductor's inductance acts rather like the mass inertia in a mechanical system. A mass resists a change in velocity and the inductor resists a change in current. The larger the mass or the larger the inductor, the greater the resistance to change.
    BR-549 likes this.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    The switch closes at 2s and opens at 12s.
    In the steady-state with the switch open, the current through the inductor is V1/R2 = 10/2 = 5A. With switch closed, it is 10/(R1//R2) = 10/1 = 10A. Now look at what V(out) must do to satisfy Kirchoff's current law as the switch is closed, then opened. V(out) drops when the switch is closed, but spikes when the switch is opened. The magnitude of the spikes is absolutely determined by what the inductor current was just before the switch transition.
