Hi guys ,
I'm developing an application for a university project
which requires high frequency AC power supply.
The frequencies are in the 10khz - 500khz range,
the voltages are 100-200v and the currents running
are below 1ma.
It seems to me like a challenging range of parameters (the freq. range can be narrowed down a bit : 100khz-300khz).
I remembered that the newer neon transformers use switching power supplies,
so i am wondering what would happen if instead of feeding a neon psu from 110ac, i will give it half the power, will the output be more or less proportional ?
And what about the frequency - some spec sheets mention that the frequency and the output V is variable, depending on the load (the neon itself).
I would appreciate any advice the seniors might have.
Also : on a related topic. I once made the mistake of asking in the forum how to generate a high voltage AC signal from a battery. The thread was closed and i realized that my question must have been really stupid. It might be totally my fault, but i never was able to figure out the fundamental issue with that configuration.... If power in < power out, what is the root reason for this problem being difficult ?
Thanks for all the advice !
Lenny
are below 1ma.
Lenny
