NEO 6M GPS TRACKER
Discussion in 'Wireless & RF Design' started by AJIN NADH, Feb 2, 2016.
  1. AJIN NADH
    Dec 18, 2014
    79
    HI,
    I bought a NEO 6M gps sensor, and connected with arduino....(tx-rx of arduino and vice versa),
    But am not getting any data, after the failure i loaded a program and tested but again failure, on searching on web i found that it has to configure...
    How can i configure it, i tested using ublox software but still its not working, how can i use this by using arduino, anybody pls help ....
    Regards,
    Ajin Nadh v a
  2. john hauton
    Dec 19, 2009
    8
    I tested the neo6m modules using an usb to serial ttl converter (making sure the voltage is correct). At least this way you can rule out software problems.
  3. camerart
    Feb 25, 2013
    518
    30
    Hi A,
    As John says, check the voltage. If this is correct, then with only the power connected, take it outside, and see if the led flashes. It could take a few minutes. If the led is flashing then it is working and should be able to be read on a terminal (e,g,Teraterm)
    C.,
