NEMA 1-15 Blades
Discussion in 'The Projects Forum' started by boredcircuit, Jan 7, 2014.
  1. boredcircuit
    Jan 5, 2014
    7
    I'm looking for a standard male USA mains plug (NEMA 1-15 or 5-15) that I can attach directly into my enclosure. Here's roughly what I'm looking for:
    http://www.heyco.com/Nylon_PVC_Hardware/product.cfm?product=PCB-Connectors
    But those are only available in bulk, it seems.
    I've searched high and low from various suppliers, but can't find anything. It can mount into the chassis or direct to the PCB -- I don't care. Molex makes similar blades, but they're not the right thickness or length.
    Honestly, it's almost to the point that I'm going to disassemble a random wall wart and make it work. And yet it feels like this should be an easy to find item!
    I've attached my schematic for reference. Sorry for the occasionally unreadable text. The project is a power monitor to sound an alert if the GFCI circuit is tripped (killing power to my chest freezer). Comments and suggestions are appreciated.
  2. inwo
    Nov 7, 2013
    2,435
    315
    Just one off or going into production?
    For one off, the wall wart idea has worked for me.
  3. inwo
    Nov 7, 2013
    2,435
    315
    For the other end, I use these with a 1" punch.
  4. inwo
    Nov 7, 2013
    2,435
    315
    How about adapting a cord plug or an IEC entry?
  5. boredcircuit
    Jan 5, 2014
    7
    One-off. Although I might make a couple of them eventually (which is why I'm avoiding the wall wart solution if possible).
  6. inwo
    Nov 7, 2013
    2,435
    315
    I found it!!!!!!!!!:D
    ps.
    I'm ordering some of these.
    $.44
  7. boredcircuit
    Jan 5, 2014
    7
    It's bigger than I'd hoped, but looks about right. What's the source?
  8. tracecom
    Apr 16, 2010
    3,878
    1,396
  9. inwo
    Nov 7, 2013
    2,435
    315
  10. boredcircuit
    Jan 5, 2014
    7
  11. inwo
    Nov 7, 2013
    2,435
    315
    It could be snapped in and used to mount slotted circuit board.
  12. inwo
    Nov 7, 2013
    2,435
    315
    1.05" square.
    Most others I used are a little less than an inch and fit loosely in my 1" square punched hole.
    These should be snug.
  13. boredcircuit
    Jan 5, 2014
    7
    So, put in two slots to match the blades and solder together? Not a bad idea.
  14. boredcircuit
    Jan 5, 2014
    7
    inwo likes this.
  15. inwo
    Nov 7, 2013
    2,435
    315
    Will your circuit fit?
  16. boredcircuit
    Jan 5, 2014
    7
    And another one ...
    http://www.budind.com/view/Plastic+Boxes/Power+Plug+Box
    Fit will be tight, but should be possible, especially with surface mount and a two-sided board. The plug takes up a third the PCB, it seems, but the few high-voltage components can fit on that section, leaving plenty of room for the rest. I'll try to lay it out tonight and see.
  17. mcgyvr
    Oct 15, 2009
    4,787
    973
  18. Leonardo Márquez
    Jun 5, 2016
    Hey, did anyone found a professional (not adapting wall warts and stuff like that) way to do this for small-production?
    I am interested in something similar to the Heyco link provided by boredcircuits user: http://www.heyco.com/Nylon_PVC_Hardware/product.cfm?product=PCB-Connectors but they sell in bulk and the minimum quantity to order is about tens of thousands. My production run is intended about a few dozens.
  19. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Yes. The solutions are in the thread.
