Negative voltage
Discussion in 'General Electronics Chat' started by corrie, Jul 14, 2011.
  1. corrie
    Jul 14, 2011
    6
    I have a circuit board with 17 volt input and three outputs with +12v, +6v and --2 volt. How do I check the negative voltage? Thanks
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    Measure it with your digital multimeter, just the same as you measure the positive voltages (of course, you need to pay attention to the sign of the displayed number to determine the voltage's polarity with respect to the input ports of the DMM).
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    If you are using an analog meter that only goes to zero, just turn the leads around
  4. corrie
    Jul 14, 2011
    6
    Thank you much for the information, it is appreciated.
