Negative voltage
Discussion in 'The Projects Forum' started by a_s_impressed, Jul 1, 2008.
  1. a_s_impressed
    Jul 1, 2008
    8
    I am using the A/D of a pic16f877. the input channel is connected to the output of an opamp which ranges from: -6 to 5 volt.
    I want to cut the negative range.
    any suggestions?
    thanks in advance :)
  2. Pulsar Flyer
    Jul 1, 2008
    When you say "cut" the negative voltage, do you mean you want to eliminate it? or wouldt you like to retain the info in the negative votage and re-scale so you only see positive voltage?
  3. a_s_impressed
    Jul 1, 2008
    8
    yes, I mean to eliminate it. the range -6 to 0 V has no meaning for me.
  4. a_s_impressed
    Jul 1, 2008
    8
    By the way, I have tried an opamp-741 as a buffer with its -Vcc connected to GND but the o/p showed the same negative input :confused:
  5. nanovate
    Distinguished Member
    May 7, 2007
    665
  6. Ron H
    Apr 14, 2005
    7,050
    657
    You can do it like this.
