negative voltage needed
ilex-xygon
Joined Aug 16, 2008
I am trying to work out how to create a -5V line to upto 8 instrument amp IC's. The outputs will be connected to a DAQ for logging by a laptop. The DAQ has ground,+2.5V and +5V powered by the laptop but no negative. The circuit used must provide a low ripple output or false readings will be given.
SgtWookie
Joined Jul 17, 2007
22,230
Actually, they ARE made by other manufacturers with different prefixes. National has the LM7660. It's pretty much an industry standard part. I didn't bother doing a lot of searches. The ICL7660S looks pretty interesting, though.
