Negative voltage in circuit
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Feb 12, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    358
    6
    I need negative voltage in my circuit with common ground wrt positive voltage
    1. One option is to generate negative supply by placing a full- bridhe & then using 7905.
    It includes lots of extra components to be used.
    2. Another option is to use TC7660. Simple to use & works good. Only problem is its output voltage falls with current. For a load current of -10 mA and a supply voltage of +5V, the output voltage would be -4.3V.
    3.I need to generate regulated -5V,-2.5V&-1.8V
    4.Any other way to do that?
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    You could use a SMPS with an isolated output. Its more-positive output terminal would connect to the common ground.
  3. crutschow
    Mar 14, 2008
    13,516
    3,386
    How much current do you need for each output?
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    There are plenty of negative rail inverter circuits online, and nearly as many off the shelf chips that do the job - or it can be as ready to hand as a 555 with a charge-pump on the output.
  5. BobTPH
    Jun 5, 2013
    807
    121
    A buck-boost converter will produce a negative voltage.
    Bob
  6. ian field
    Oct 27, 2012
    4,459
    792
    An inverter that outputs the opposite polarity to the input doesn't have to be buck-boost topology to span output voltage both above and below the input voltage.
