Negative Voltage Follower
Discussion in 'General Electronics Chat' started by baseball07, Nov 13, 2009.
  1. baseball07
    Thread Starter Active Member
    Apr 24, 2007
    39
    Hi everyone. Can a voltage follower be configured for negative voltages rather than positive ones? Say, instead of Vin=Vout=2V, have vin=vout=-2V. Thank you.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Yes, if you have the required power supplies for the circuit, either dual polarity or "positive ground".
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    It is not a follower it is a unity gain inverter. Easy if using op amps.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What makes you think a follower won't follow negative voltages?
  5. alphacat
    Jun 6, 2009
    186
    To the OP
    You just need to worry about the bias point of the transistor.
    If you insert a negative input DC voltage, then you need to make sure that the VEE (or VSS) of the circuit is negative enough in order to have VBE =~ +0.7V (or to have VGS > VTn).
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Did you misread the OP's statement?
