Negative Twisted Ring Counter
Discussion in 'The Projects Forum' started by MrL, Dec 14, 2009.
  1. MrL
    Oct 21, 2009
    46
    This is a very small part of my project. A typical 4-bit twisted ring counter gives four positive-going strobes, as shown below in the right hand diagram:
    http://en.wikipedia.org/wiki/Ring_counter
    I was just wondering what the waveform would be from a circuit built to give four negative-going strobes?
    Thanks.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Well, with TTL and CMOS level logic, you basically have two choices: 1 or 0. There IS no -1.
    There are also tri-state devices, which have high impedance mode; primarily used for connections to data buses.
  3. Bernard
    Aug 7, 2008
    4,248
    424
    Put inverters on outputs. Sounds like a Knight-rider project.
  4. loosewire
    Apr 25, 2008
    1,584
    435
    I'm having trouble In your post If you are pro or con of our beloved Sgt.
  5. Bernard
    Aug 7, 2008
    4,248
    424
    Loosewire, to whos post are you referring? The Sgt. is the best.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Use the /Q (not Q) outputs of the flip-flops. Or, use the Q outputs in reverse order.
