Negative resistance?????
Discussion in 'General Electronics Chat' started by spinnaker, Jan 14, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,089
    1,183
    How is it possible to read Negative resistance? I can see if you have power connected to the circuit but I have none.
    I have a simple surface mounted connector. It s hard to see under the pins so I am guessing I have a short somewhere but why would I be reading negative resistance?
    The only other thing in the circuit are some pullup resistors with the opposite end disconnected.
    What is strange is if I reverse my leads of the ohm meter I read infinite ohms.
    Could a bit of flux down between the connectors cause a junction that forms a battery??
  2. joeyd999
    Jun 6, 2011
    2,757
    2,936
    Or, you could have a charged cap on the node you are trying to measure. Disconnect (isolate) all connections on one side of the resistance prior to your ohms measurement.
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    A negative reading with the meter one way round, and infinite the other way round, actually fits very well with a DC voltage being present.
    Apart from charged capacitors, backup batteries or some kind of AC pick-up being rectified by a semiconductor somewhere may be providing the DC.
  4. spinnaker
    Oct 29, 2009
    5,089
    1,183
    No caps in the circuit. Just the connector and a few pull-up resistors.
    As mentioned there are pull-up resistors but only the end on the resistor connected directly to the connector is connected.
  5. spinnaker
    Oct 29, 2009
    5,089
    1,183
    But there is no voltage source at all connected. That is the mystery. It is a very simple circuit. Just a connector and some resistors. It is an SD connecter on a break-out board.
  6. kubeek
    Sep 20, 2005
    4,689
    806
    Low battery in meter?
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    Try measuring across the mystery device with a voltmeter.
  8. Lundwall_Paul
    Oct 18, 2011
    222
    19
    What does your meter read when the leads are shorted and is the reading stable?
  9. spinnaker
    Oct 29, 2009
    5,089
    1,183
    Now I feel stupid. :mad: I measured 3V. As soon as I saw that I knew something was up. It was coming from my MCU that was connected via a jumper that I know I disconnected. Must have been that ghost that connected it back up, that hangs around here and causes trouble. :)
  10. crutschow
    Mar 14, 2008
    13,505
    3,378
    Poltergeists that move things, and micro Black Holes (that cause small objects to disappear as soon as the hit the floor) are very common in any electronics lab.:D
