Negative P/S
Discussion in 'General Electronics Chat' started by DexterMccoy, Mar 20, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    This Op amp is after a Power supply regulator that is a positive +10 volts
    The op amp inverts the +10 volts into a -10 volts to make a negative supply
    My question is what does Q7 do? what function does it do in the circuit?
    What kind of circuit is this called please, the op amp and Q7 combination to turn a positive voltage into a negative voltage?
  2. DexterMccoy
    Feb 19, 2014
    429
    here is the schematics
  3. magnet18
    Dec 22, 2010
    1,232
    125
    Q7 is a buffer, it provides more current to whatever is down the line than the op amp could, the op amp would normally only be able to provide a couple mA, a transistor can provide much more
    the opamp is in a negative feedback inverting setup
    the transistor is a buffer
    I would call it a "negative feedback voltage inverter with a current buffer", I don't know if it has an official term
  4. DexterMccoy
    Feb 19, 2014
    429
    Thanks for the help
    But the Q7 buffer has no biasing resistors, it's direct to supply voltage on the collect and direct on the emitter to the output
    So the Q7 is not biased? any reason why
    I thought OP amps outputted more current than a transistor did
    Plus the Negative supply rail is not regulated, only the Positive supply
    I have seen this type of stuff often when the negative supply is no regulated but the positive supply is, any reason why?
    I need supply doesn't source current? only the positive supply sourced current more?
  5. ErnieM
    Apr 24, 2011
    7,442
    1,628
    It is biased by the nature of the op amp feedback. The only thing missing is anything to limit current in case of a fault downline.
    Typically it is the other way around.
    Necessity. Cost.
    Positive sources, negative sinks. That's typical in most supplies. Offhand I do not know of a positive regulator that sinks or a negative regulator that sources.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
  7. DexterMccoy
    Feb 19, 2014
    429
    How is the transistor biased by the op amps feedback?
    How would you limit the current in cause of a fault?
  8. magnet18
    Dec 22, 2010
    1,232
    125
    transistors have a current gain
    Iout=Ibase*β (some multiplication factor, usually in the hundreds)
    usually a resistor or a fuse, depending on the scenario
    there are also much more advanced methods
  9. DexterMccoy
    Feb 19, 2014
    429
    Yes they use milliohm resistors in series as a fuse , a series resistor on the output of the p/s. But these aren't current limiting circuits
  10. magnet18
    Dec 22, 2010
    1,232
    125
    resistors by nature will only allow some certain maximum current for a set voltage range
  11. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    So I was playing with this circuit in multisim because it looked like something I actually needed.
    Using an LM148FK, it shows as having a -18V output, with an 18V input.
    If I use an LM148J then it only shows as being 157mV.
    What gives?
  12. atferrari
    Jan 6, 2004
    2,672
    785
    Dexter, is it possible that you post the whole schematic? If you do not like to disclose it, it's OK for me.
  13. kubeek
    Sep 20, 2005
    4,691
    806
    Spice opamp models have different levels of complexity, and IIRC model 2 doesn't include the supply voltage limits, while level 3 does.
  14. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    I don't quite understand.
    does that mean if I buy any LM148, the result would be -18V out, with +18V in?
  15. kubeek
    Sep 20, 2005
    4,691
    806
    With what power supply? Please show your schematic.
  16. DexterMccoy
    Feb 19, 2014
    429
    Why are the diodes in the middle , it's separates the filter caps
    Mostly I see the zener diodes at the END of the power supply, not placed in the middle
    Why are the zener diodes placed in the middle of the filter caps?
  17. kubeek
    Sep 20, 2005
    4,691
    806
    Why do you think it matters where they are drawn on the schematic?
  18. DexterMccoy
    Feb 19, 2014
    429
    Because the zener diodes are before 10 filter caps and after 4 filter caps
    That must be a reason for this
  19. MrChips
    Oct 2, 2009
    12,648
    3,459
    Nope.
    You have to learn the purpose of decoupling capacitors and why the designer drew them that way.
  20. DexterMccoy
    Feb 19, 2014
    429
    Yes they are decoupling caps but are drawn like filter caps right?
Thread Status:
