negative or minus?
Discussion in 'General Electronics Chat' started by Steve1992, Aug 14, 2009.
  1. Steve1992
    Thread Starter Senior Member
    Apr 7, 2006
    100
    Is there a correct convention when communicating in tech. speak.
    Eg. "....-23...." Would you say "minus 23" or "negative 23"?
    Or am I just being pretentious to ask such a question?
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    I tend to use negative.
    Minus in dutch means subtract.
    Greetings,
    Bertus
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    I tend to use the two expressions interchangeably. I have never misunderstood a discussion in which the two methods of denoting that a signal was non-positive were used.
    hgmjr
  4. ELECTRONERD
    May 26, 2009
    1,146
    16
    Either appellation is fine. You might have one that you prefer over the other, but they are both technically correct.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    According to my old dictionary, minus can be a preposition (as in, seven minus four), an adjective (minus value), or less frequently, a noun.
    Negative can be an adjective (as in, negative value), adverb ("negative" meaning "no"), or verb (as in negated).
    Minus is not a verb; negative is not a preposition.
    So, as adjectives, they are synonyms. However, they cannot be used interchangeably in all sentences, as bertus points out.
    John
  6. count_volta
    Feb 4, 2009
    435
    24
    In Russian we also say either negative or minus when talking about that particular terminal of a battery.
  7. ELECTRONERD
    May 26, 2009
    1,146
    16
    Say, are you Russian count volta? Cool! I had a friend who was Russian.
  8. ELECTRONERD
    May 26, 2009
    1,146
    16
    When you say it can be a preposition "as in, seven minus four" how does that work? These are prepostions: behind, on, around, and others. How does this apply to "as in, seven minus four"?
    I never really was good at English...:rolleyes:
  9. count_volta
    Feb 4, 2009
    435
    24
    Yea I am. Would you consider replying to my motor as generator thread? Its a simple question, but the amplitude of people's interest in it seems half rectified at best. ;)
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Forgive me, a negative joke.
    A professor was stating, "In Russian, a double negative can still be a negative, and in some other languages, two affirmatives can be a negative, but there is no case in English where two affirmatives are a negative."
    From the back of the class a voice was heard, "Yeah. Right."
  11. count_volta
    Feb 4, 2009
    435
    24
    LOL thats pretty funny Bill. Seriously. :D
