Negative ions generator
Discussion in 'General Electronics Chat' started by atferrari, Oct 15, 2014.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,667
    784
    Asuming the circuit is correct, I cannot grasp how it works.
    Could anyone explain it?
    Thanks for any help.
  2. wayneh
    Sep 9, 2010
    12,388
    3,245
    The 555 sends a square wave to the MOSFET, switching a high current to the step up transformer. A large negative pulse voltage appears at the wire point, allegedly generating negative ions by shedding and attaching electrons to them.
  3. atferrari
    Jan 6, 2004
    2,667
    784
    Is the circled terminal of the transformer returned properly? To +12V?
  4. GopherT
    Nov 23, 2012
    6,315
    4,035
    The arrow isn't current flow or a diode. It just indicates that that wire eventually finds itself a +12v terminal to connect to.
  5. wayneh
    Sep 9, 2010
    12,388
    3,245
    I think so. The big negative pulse gets referenced to +12V instead of 0V, but that's trivial compared to the voltage involved. I'm not really sure why it's not referenced to ground, but it shouldn't make much difference.
