Negative fundamental forces
Discussion in 'Physics' started by sirch2, May 15, 2014.
  1. sirch2
    Jan 21, 2013
    1,008
    351
    We were just having a conversation about the possibility of anti-gravity and one of the guys said "why not, there are negative versions of the other fundamental forces".
    I had never thought about this and Google isn't very forthcoming on the subject. So are there actually negative versions of the other forces? I can see that probably a positron has the opposite force to an electron but does an anti-proton (or whatever it is called) have an opposite gluon to a proton?
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I actually question the assumption that there are negative versions of the four fundamental forces. What is your evidence for the existence of anti-forces.
  3. sirch2
    Jan 21, 2013
    1,008
    351
    I don't have any, that's why I was asking the question. I think forces are one of those things (like inertia and anti-bodies) that we all talk about and think we have some understanding of but in reality we never get beneath the surface.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    also, why are some forces, electricity, magnetism and such bipolar and yet gravity is not?
  5. sirch2
    Jan 21, 2013
    1,008
    351
    Well electricity and magnetism are the same force and again it goes back to the same question they may appear to us to be bipolar but are there two types with opposite polarity, OR are the two poles just a manifestation of action along a single vector?
    I think it is also interesting that the only force we have managed to make use of is the one that is human-scaled, i.e. the electo-magnetic force. We can pick up a magnet and get a feel for how it works and we can see lightening. Imagine what we might be able to do if we could do the same with atoms or planets...
  6. nsaspook
    Aug 27, 2009
    3,009
    2,350
    Obviously we use the other forces daily to transform that power in the electro-magnetic force. Gravity for hydro, the nuclear force for fission generators for examples. We can sculpt individual atoms today.
    We've looked for anti-gravity with anti-matter but it's attracts just like normal so gravity IMO seems more fundamental than matter. My current ideas are that matter is the singularity of gravity and charge is the singularity of the electro force that are separated specialized parts of the original big bang singularity. What is really physical in the universe is not atoms or matter, it's the things we call forces that we describe in fine detail how they work but don't have a clue why they work and what they really are.
    That doesn't mean we or matter doesn't exist or this reality is less real, it's just a viewpoint. (that's just a consistent as saying 'forces' are just mathematical constructs describing matters interaction with other matter in the universe)
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    electricity and magnetism are the same force? then why dont I ever find an electric charge between ends of a permanant magnet? why dont I find a magnetic field on a battery unless current is flowing? they seem to be convertable easily, but not the same thing.
  8. nsaspook
    Aug 27, 2009
    3,009
    2,350
    Relativity unites them into one dual force.
    http://en.wikipedia.org/wiki/Relativistic_electromagnetism
    http://www.physicsforums.com/showthread.php?t=116693
    http://physics.weber.edu/schroeder/mrr/MRRtalk.html
  9. bretm
    Member
    Feb 6, 2012
    152
    24
    Combining this with nsaspook's relativity references: if you're carrying a statically charged object in your hand, you won't find a magnetic field. But if someone walks past you with the charge in their hand, you will (if you could measure tiny enough fields). The charge has motion relative to you, and moving charges are current and have magnetic fields. So from your frame of reference there is a magnetic field and from the other person's frame of reference there isn't.
  10. nsaspook
    Aug 27, 2009
    3,009
    2,350
  11. alfacliff
    Dec 13, 2013
    2,449
    428
    in other words, as long as you add energy to a magnet, it becomes electricity? moving a conductor through a magnetic field creates electricity, but does not use up the magnet. the motion through the magnetic field makes the current flow. if you add energy to water, it becomes steam, but do you call ice steam?
  12. nsaspook
    Aug 27, 2009
    3,009
    2,350
    We call it a different phase of the same molecule (water).
    It's pretty easy to understand how the EM force operates with changes in motion, time, separation and density to produce the voltage/current effects we see in circuits if we see charge as fundamental like we see that the structure of h2o is fundamental to understanding the phases of water.
  13. alfacliff
    Dec 13, 2013
    2,449
    428
    in other words, the nature of water is changed by the energy level of the water. but I have never seen a magnet strong enough to have an electric field or measureable voltage on it without the addition of additional energy of moving a conductor near it. a non moving conductor has no voltage field or current low when near a magnet.
  14. nsaspook
    Aug 27, 2009
    3,009
    2,350
    What implies power IRT to electricity? You must have both fields for the simple power calculation. A static magnetic field from a magnet has no power to perform work, if it did the magic magnet perpetual motions machines on the web would actually work. The origin of magnetism in a magnet is Quantum-mechanical.
    R. Feynman has mentioned in his famous lectures (Vol 2, 34):
    https://www.youtube.com/watch?v=MO0r930Sn_8
  15. sirch2
    Jan 21, 2013
    1,008
    351
    Some good stuff there and I'll read through it in more detail when I get time but what about negative nuclear and electro-magnetic forces, do they exist as distinct things?
  16. BR-549
    Sep 22, 2013
    2,167
    416
    There can be no negative force unless you turn the clock back. You are confusing force with direction. The reason you have never seen a negative gravity pole is because the way gravity is made. Gravity is generated by vibrating neutral dipoles. The most common neutral dipoles is the H2 atom. Although all neutral dipoles generate gravity. As the proton and electron oscillate.....electrons do most of the moving because of inertia(the electron moves a lot easier than the proton). Being that the proton and electron have the same charge, but they travel different lengths.....the oscillation is not symmetrical. A very small amount of energy is lost due to radiation. This radiation is cumulative and attracts all particles together. If the proton were doing most of the moving.....gravity would be repulsive. The Cosmic Background Radiation is a map of the decay of gravity. It's a map of where matter is. Gravity has density. The force of gravity does not attract in a straight line. It has a chiral effect and it spirals. This is why galaxies rotate the way they do without dark matter. Einstein was wrong. Length never changes anywhere, anytime. Our universe is rock solid. Gravity decays at an exponential rate. It's not decaying to fast now, but in the past it was very, very strong. When you look at old distant objects.....you see large red shifts.
    There is no such thing as a negative force. If you come across a - sign in front of a force term....it denotes direction or the equation is wrong for physics.
  17. Alec_t
    Sep 17, 2013
    5,966
    1,133
    If gravity accounts for attraction forces between matter, and anti-gravity would result in repulsion forces between matter, was the Big Bang caused by anti-gravity?
  18. BR-549
    Sep 22, 2013
    2,167
    416
    There is no evidence of "big bang". The CBR is not leftovers from the big bang. It is the decay of gravity. The universe is not expanding rapidly. The large red shifts are due to the intense gravity at the time of emission, not due to acceleration. That's why all of them have high red shifts. Gravity is decaying. The universe is expanding SLOWLY. Gravity was much greater in the past.
  19. Alec_t
    Sep 17, 2013
    5,966
    1,133
    The red-shift is no more evidence of that than it is of the Big Bang.
  20. BR-549
    Sep 22, 2013
    2,167
    416
    I wasn't saying red shift proved my statement. I was trying to show the true cause of CBR. A lot of observations have been misinterpreted due to GRT and QM. The real structure of matter was derived from experimentation and computer modeling about 15 yrs. ago. All matter is composed of rotating charge. After studying this structure, and reviewing past experiments......A new equation for electric charge was derived. A little while after that the force of inertia was found. Inertia is a feedback effect. There is no mass. Only charge, electric field and magnetic field. Mass is apparent. The charged ring....particle....is an antenna.....the circumference is the wavelength. The circumference changes with energy state. It receives and transmits many different colors. About five yrs. ago.....radioactive decay and gravity were derived. This is all that was needed for the UNIVERSAL FORCE LAW. I know what matter is. And I know how it moves. It is simple, elegant, genius and true. It proves true in the lab and it explains everything we see. I can not prove this to you. But you can prove it to yourself. Do a search on google for electron structure. You will know when you find the right place. May the universal force law be with you.
