negative feedback
Discussion in 'General Electronics Chat' started by anira, Oct 2, 2005.
  1. anira
    Oct 2, 2005
    hi..
    i want to ask this question..
    the benefit of negative feedback normally are accompanied by 2 disadvantages,decrease in gain and tendency for oscillation.What is the simplest and most common method used to overcome the problem?how to compensate a unity-gain feedback configuration?
  2. sanjeev203
    Sep 19, 2005
    7
    Use of series resistance at the output and use of compensating capacitor parallel to the feedback stablizes the output.
  3. mozikluv
    Jan 22, 2004
    1,437
    hi,
    pls. clarify your question on "how to compensate a unity-gain feedback config."
  4. jidhishs
    Oct 21, 2005
    you can use a capacitor parallel with a resistor as the negative feedback.it will reduce the oscillations..stabilizes the circuit..but the bandwidth will be less...
    else use a PID controller...means an integrator , a differntiator, and the proportional controller nothing but your unity gain amplifier connected parallely....thi salso will reduce oscillations...
  5. jidhishs
    Oct 21, 2005
