negative edge triggered counter
Discussion in 'The Projects Forum' started by mathewctom, Oct 7, 2006.
  1. mathewctom
    Oct 7, 2006
    hi
    could you be kind enough to provide me with the names of few common ICs that are used for making negative edged counters.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A 74xx04 hex inverter will transform a positive edge triggered counter into a negative edge triggered counter with probability certain.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Hard to understand your question. The counter ic's are already in existence. You just want to select one that has all your requirements, including the negative edge trigger. It's all part of the spec sheet on the device, and is generally part of the one-line device description.
    S papabravo said, adding a 74xx04 to the input will invert the trigger, and make a positive-edge trigger device go on a negative signal. Sometimes it takes an understanding that you can always get the logic to perform the function you wish.
