Negative edge trig device - Multisim
Discussion in 'The Projects Forum' started by Philz, Dec 2, 2007.
  1. Philz
    Dec 2, 2007
    Need a simple negative edge triggered device or circuit that i can insert into a multisim simulation. (So the device needs to be available on there.)
    The attached diagram shows what output waveform i require and the part of the circuit where its needed.
    Any Help or Advice would be Appreciated
    Thanks Philz
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you considered using an inverter in series with the clock signal? Or does that introduce other complications?
    hgmjr
  3. GS3
    Sep 21, 2007
    408
    35
    I am not sure I undertand. You want a negative edge triggered monostable? Anything wrong with using a 555 for that? You know, specially since the rest of the circuit is already full of 555 monostables. Am I missing something?
    Aside: Using a graphic most of which is empty white space is a waste. Using JPG is further waste and just degrades it. I recommend you use PNG and trim it.
  4. Philz
    Dec 2, 2007
    Yes,
    It adds complications because I thought of putting an inverter on the output of a single monostable but this makes the output high befroe the trigger.
    The wave form i need is low before trigger, low for time (t) and then high then latched high indefinatly.
    thanks Philz.
  5. Philz
    Dec 2, 2007
    Do you know a circuit diagram or website address for a negative edge triggered monostable bearing in mind i would like any components used to be simulated in multi-sim.
    thanks Philz.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you looked into Flip-Flops such as J/K, SET/RESET, or D-type?
    hgmjr
  7. GS3
    Sep 21, 2007
    408
    35
    Again, I'm not sure I follow you. The 555 is negative edge triggered like you are showing in your diagram. Why don't you just put anothr one in there? Maybe I am completely misundertanding the problem but it seems to me a 555 in there would do exactly what you want. Or what am I missing?
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Maybe he is not including an RC differentiator in front of pin 2. See the datasheet (or GS3's schematic).
