Negative and Positive Bridge Rectifier Circuits
Discussion in 'General Electronics Chat' started by Lainya, Apr 13, 2008.
Thread Status:
Not open for further replies.
  1. Lainya
    Apr 13, 2008
    Can anyone explain to me why I would get a smaller DC reading across the load of my circuit than the predicted value even when the rectified peak voltage is almost the same as my predicted value? See revised thread
  2. rubberman
    Apr 13, 2008
    There is no much information there. Has the load of your ciurcuit the same value as the input load of your probe or measurement device?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Can you post your circuit? Click the "go advanced" button below, and attach a .jpg or .png image of it.
  4. JoeJester
    Apr 26, 2005
    3,401
    1,218
    Smaller is a relative term ... how much smaller? 12 to 11 is smaller ... but certainly within 10% of the desired (12).
    Post your circuit and describe or post the load.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Their right, need input.
    A likely cause is if you're using a transformer it is loading down a bit, and coming out with slightly less AC under load.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I am going to lock this thread since it has been revised & reposted.
Thread Status:
