Needed Help with this project !!! Please Help !!! Urgent !!!
Discussion in 'The Projects Forum' started by parvez_19_01, Apr 6, 2009.
  1. parvez_19_01
    Apr 6, 2009
    12
    Hi!
    Please help me as I am trying this project from more than a month
    I am a newbie
    But I know basics
    I have 160 leds with a power supply of 5v
    I want to glow each of them after a delay of 0.00625 second
    In this way all of them can glow in 1 second (0.00625 * 160 = 1 sec)
    it should look like a running light
    Please help !!!!!!!!!!!!!!!
    Regards
  2. galal_mounir
    Member
    Apr 5, 2009
    29
    would u like to use a microcontroller or just simple components cuz if u r going to use simple components ur going to have a hell of a circuit its going to be very large while if u use a microcontroller it will be much easier but u need some microcontrolling basics
  3. parvez_19_01
    Apr 6, 2009
    12
    Could u give me both the options please
  4. galal_mounir
    Member
    Apr 5, 2009
    29
  5. parvez_19_01
    Apr 6, 2009
    12
  6. parvez_19_01
    Apr 6, 2009
    12
    And if please u can tell me the option with simple components
  7. galal_mounir
    Member
    Apr 5, 2009
    29
    so u need a 160 bit counter :| thats alot man cant u reduce the 160 leds a bit
    mmmmm....
    anyways to make this circuit using simple components u would need to use the 555 oscilator as a timer to time the pulses and use a shift register which shifts 1 so for example if it is 4 bits the first code will be 0000 then shift right 1 after the first clk so it will become 1000 then shift another 1 after the second clk so it will become 1100 and so on so u need to search for the highest shift register u can get, for this u would need a SIPO shift register and put 1 in the serial input
  8. parvez_19_01
    Apr 6, 2009
    12
    Sorry I am not that savvy
    Please help me with simple components
    Can u let me one thing that if we use a capacitor
    which charges fully in a second
    and as it charges something which we trigger at specific interval
    as the voltage increases something like that, you can better suggest
    Please use, Very basic components
    Regards
  9. galal_mounir
    Member
    Apr 5, 2009
    29
    does that mean you dont want to use any ICs ????
  10. parvez_19_01
    Apr 6, 2009
    12
    ya correct!
  11. galal_mounir
    Member
    Apr 5, 2009
    29
    OMG !!!!!!!!! :| :| thats nearly imposible you need to use ICs man at least for the timing part its impossible to design a ckt like that using only resistors and caps
  12. parvez_19_01
    Apr 6, 2009
    12
    Cant use resistor capacitor transistor and
    RC filter circuit
  13. galal_mounir
    Member
    Apr 5, 2009
    29
    deadly hard and wont be acurrat
  14. parvez_19_01
    Apr 6, 2009
    12
    Can u tell me how to put a led on once the capacitor is fully charged?
  15. galal_mounir
    Member
    Apr 5, 2009
    29
    you will need to use a comparator which is an IC as well :S to compare the capacitor voltage if it is fully charged or not
  16. galal_mounir
    Member
    Apr 5, 2009
    29
    cant u use any IC's at all??? not even 1 ?????????
  17. parvez_19_01
    Apr 6, 2009
    12
    cant we use rc filter circuit to trigger at one certain point of voltage
  18. parvez_19_01
    Apr 6, 2009
    12
    I am not savvy to start with any ic
    I would like to know how to do it without IC
    I want to know how the current flows from one part of the circuit to other
    IC does solves that
    creating a delay circuit without IC is also possible
  19. parvez_19_01
    Apr 6, 2009
    12
    sorry IC doesn let u know how the current passes
    as it is all integrated
    making a circuit with all basic and simple components lets to know how it flows
  20. galal_mounir
    Member
    Apr 5, 2009
    29
    u need a comparator to give u the trigger u need when the capacitor is fully charged other than that i cant think of a way to give u a pulse when the capacitor is fully charged
