I think you'll need individual LEDs. The LM3914 is the best part to use for the driver. You have a choice of dot mode or bar mode. Dot mode requires less power. If you want maximum brightness with bar mode, you will probably need to add resistors in series with the LEDs, to prevent overheating of the LM3914.Thanks Ron for your ideas so far. Sorry I had to leave so abruptly yesterday. Here is a detail of what I'm trying to do. I'm trying to represent the position of the lever in the drawing. It is for a large amprage switch (1200-2000 amp). The lever accuratly depicts the position of the switch. (fully open, fully closed or somewhere in between) The object is to push a button and read an LED bar graph of the switches position. There is little room for any other type of measuring device thus the pull string mounted high. As you can see the travel of the pull string is around 1/2" from fully retracted to around 4 11/32 of the 4 3/4 fully extended device. So to answer your previous question, I'd like one to adjust the .25 - 1" range and the other to cover the 4.25 - 4.75 range.
I've been shopping for bar graphs. Can't seem to find what I want and am afraid I my have to make my own. I want a 7 or 10 light red on the bottom and green on top with yellow in between. I also want it fairly large and easily visible. Say 4" long. I thought the arrays that are available are a little small. I'm open to suggestions.
Again Ron thanks for your input and time. It is appreciated. If any other information is needed please ask.
p.s. Did you get your hot tub to sparkle?
We can probably design something that will work if this part looks OK.
I did get the hot tub cleaned up. I procrastinated for several hours because I dreaded the job. When I got finally got around to it, the sun was high in the sky. I found out why they are called hot tubs.
