Need your Advise of using DC Motor
Discussion in 'General Electronics Chat' started by mpcotuong, Sep 22, 2010.
  1. mpcotuong
    Aug 26, 2010
    170
    Hi All,
    Does anyone know if I am using the DC Motor one direction for 10sec then go other direction for 10sec. Will DC motor will be damage later on because switch back and forth direction? Please advise.
    Thanks,
    Kevin
  2. Jaguarjoe
    Apr 7, 2010
    770
    90
    If the motor comes to a complete stop before shifting direction you'll be OK.
  3. mpcotuong
    Aug 26, 2010
    170
    The Motor will turn other direction right away after time out of 10sec. Will it work ok for long run?
  4. Kermit2
    Feb 5, 2010
    3,847
    963
    It depends. How much current is the motor drawing during its reverse? How much is it rated for? Is the motor being reversed electrically only or both electrically and mechanically?
  5. mpcotuong
    Aug 26, 2010
    170
    Yes, both electrically and mechanically. It 's 1A.
  6. Kermit2
    Feb 5, 2010
    3,847
    963
    Then there will be bearing stresses and electrical heating created by back EMF. Use a motor designed for 100-200% more power than you are actually using and the stresses won't cause any damage in the long term.
    Why not use stepper/servo motors which are designed for such rapid reversal? :confused:
  7. mpcotuong
    Aug 26, 2010
    170
    Do you have in mind what model stepper/servo motors I can use? I need it for 9VD to 12VD input.
  8. Kermit2
    Feb 5, 2010
    3,847
    963
  9. mpcotuong
    Aug 26, 2010
    170
    The website look good for supply.
  10. Bernard
    Aug 7, 2008
    4,235
    414
    How many hours a day does motor recycle? I would put a 1Ω, 1W resistor in series with motor [12W if allowing for protracted stalls.] Bypass motor & relay contacts with .1 cap. And remember that you can lift & lower arm with a cam without reversing motor.
  11. Bernard
    Aug 7, 2008
    4,235
    414
    Reversing small motors with 1 Ω, 5W in series with 12V, 4A supply & DPDT switch:
    M-1 0Ω, 2A no load, 5A loaded; 2 sec to rev, resistor smoking.
    M-2 1Ω, 1A no load, 2A load; 1 sec to rev, resistor hot.
    M-3 13Ω, 50mA no load, 600ma loaded; 1/10 sec to rev, resistor cool.
    M-3 sounds about like motor suggested on prev. post.
  12. majsyd2010
    Member
    Aug 29, 2010
    61
    Very useful Information .... Liked it
