Have a question on the USA voltage system.There is nothing comes to mind, particularly if one side of the supply was referenced to ground, say, it would not make sense.
If it were me, I would be doing some tracing of the wiring/components on the down stream side of the blown fuses in an effort to analyze why they should blow.
If the equipment requires 230/240v 1ph you should not have to worry about the neutral in N.A. use.
Max.
This tool is being installed in a small warehouse that has plenty of room at the fuse panel.
I'm assuming the panel will have 2 or 3 legs of 120v a neutral leg and a ground leg... Would that be the norm set up..?
If that is correct. Should I be running a neutral to the tool the tool and connecting it to the ground ... Not sure if this is a stupid question or not but have to ask
Thx
Gordon
