Hi.. new to forum.
I'm installing a tool with no schematics in USA, Colorado to be exact. The system came from the UK and states below requirements.
230VAC +/- 5% 50/60Hz, single phase (230VAC between Live (hot) and earth
(ground), 0VAC between Neutral and earth (ground), 230VAC between live (hot)
and neutral)), 32A fused with (with 10,000AIC rating) supply with separate ground.
Earth fault loop impedance <0.1Ω. Isolator required within close proximity of
operator and capable of Lock and Tagout
How do I make this work in the USA. what do I need?
Gordon
Gordon
