Need transistors numbers suggestions
Discussion in 'General Electronics Chat' started by gaetan8888, Mar 24, 2009.
  1. gaetan8888
    Thread Starter Active Member
    Nov 14, 2008
    41
    Hello
    Any suggestions of npn low noise small signal transistors who goes up to arround 500 mhz ?
    Thank
    Bye
    Gaetan
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Do you have more specs ?
    Voltage, current , power ?
    Perhaps take a look at the BFR96.(see datasheet).
    Greetings,
    Bertus
  3. gaetan8888
    Nov 14, 2008
    41
    Hello
    The circuit will work at 5v voltage at arround 30 ma.
    Thank
    Bye
    Gaetan
  4. gaetan8888
    Nov 14, 2008
    41
    Hello
    I know BFR96 and also BFR92, they goes up to 5ghz.
    A bit high for my use and I can not find any of those here arround.
    Here is the circuit, it is a low jitter clock.
    They suggest transistors with about six time the max crystal frequency.
    Thank
    Bye
    Gaetan
  5. loosewire
    Apr 25, 2008
    1,584
    435
    gain band width 500 mhz a b c amp
    more info
    still looking for low noise if needed
