Need to understand a transistor part marking
Discussion in 'The Projects Forum' started by JerryEngineer, Nov 30, 2015.
  1. JerryEngineer
    Nov 30, 2015
    I'm working on a project for a friend where he has an old organ (4140 Wurlitzer) that was built in the 1960's. The schematics for it are no longer available. I've isolated the functionality problem to several TO-92 transistors on one of the tone generators. There is no part marking on the devices except for "891". Does anyone have an idea how to cross reference this to a part number? If not, is there an easy way to identify a potential replacement part?
  2. Dodgydave
    Jun 22, 2012
    5,153
    770
    Chances are its silicon, if you can compare it with others on the pcb, use a multimeter on diode test, or remove the transistor and put it into a dvm/transistor tester.
    Could be 2sd891, 2sc891, or it could be a unijunction fet, the list is endless....
    Any pictures?
  3. GopherT
    Nov 23, 2012
    6,309
    4,030
    @JerryEngineer
    Likely a 2n891
    A small silicon controlled Rectifier (SCR). Google for limited old-school datasheet.
  4. recklessrog
    Member
    May 23, 2013
    346
    102
    It could also be a 2SA891 which is listed as similar to BC327A, BC638, BC640, 2SB647.
    Silicon pnp 60v 0.5A 0.35W 100MHz
    Info from VRT comparison table vol 2
  5. Brevor
    Apr 9, 2011
    282
    56
    I serviced organs many years ago, many transistors used in organs can be subsituted with generic NPN and PNP transistors. I suggest you trace out the part of the circuit the transistor is used in and also measure a good transistor in order to determine which type it is. (NPN, PNP or other) Then replace the bad ones with a generic 2N3904 or 2N3906 transistor.
  6. Brevor
    Apr 9, 2011
    282
    56
    No, Wurlitzer didn't use foreign transistors in their products.
  7. SLK001
    Nov 29, 2011
    851
    243
    In the 60's, there were plenty of American made transistors that would have been used in American products. Your transistor was probably marked with a house number, so unless you have the original schematic or detailed parts list, you're going to have to characterize a functional "891" device to find a modern substitute.
    If you find many "891" devices on the boards, you can probably just measure the VCC and select a generic version that has a voltage rating above your VCC measurement.
  8. JerryEngineer
    Nov 30, 2015
  9. JerryEngineer
    Nov 30, 2015
    Thanks all for your valuable input. I was able to figure out the transistor type that I needed (2N3904) and the board is now functional again. Thanks again!
