I live in an area with a high water table. When it rains as little as 1/2" my sump pump starts to run within an hour of the rain starting. When I get aver 2" of rain the pump cycles every 30 seconds. I would like to have a lcd digital timer that upon the pump starting, resets the time to zero and starts to run until the pit is empty, then the timer stops. That way I can look at the timer between cycles and see if the time is getting longer or shorter. Any ideas on what I need to create this monitoring circuit. It can be located right in the area of the sump pump. Thanks!
