Need to reduce rpm's of 6 volt motor
Discussion in 'General Electronics Chat' started by mvp204, Nov 6, 2007.
  1. mvp204
    Nov 6, 2007
    Have one of those spinning wing decoys with 6 volt motor. Want to reduce the speed of the motor to about half. Is there a potentiometer or resistor available for this? Thanks, Mark
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Use the site search function to find "PWM" or "Pulse Width Modulation." Plenty of good advice for the reading.
  3. nomurphy
    Aug 8, 2005
    567
    12
    You mabe able to use a rheostat, which is the same thing used in old toy trains (the big black box with the knob on top), and in slot-car hand controllers. It mainly depends on how much power the rheostat (pot) will need to dissipate vs. the voltage /current required by the motor -- which is why they tend to be so large.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    As a cheapo suggestion, eliminate one battery (this assumes the decoy has 4 AA or C cells). Cut a dowel to length, wrap it in foil, and use it to take the place of one battery. This will reduce the voltage and possibly make the motor run slower.
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
