I am building an analog to digital converter of the SAR type. I've got most of the circuit designed and tested. All that's left is the sample and hold and comparator circuits. I need to purchase a bunch of transistors for my project. This will be an 8-bit SAR ADC running at 12 MHz, which translates to 1.5 MHz for the sample and hold circuit. The transistors need to be sized correctly, but data sheets don't give the gate width's for the transistors. If I understand correctly, I need to be looking at the TpHL and TpLH. I could use some tips on how to do the search via Mouser or Digikey for the transistors that will work for my project. The comparator circuit I plan to use is shown in the picture. This is a dynamic two-stage latched comparator.
Thanks for your help,
Mike
Mike
