Need to pulse vibration unit
Discussion in 'General Electronics Chat' started by Jlwoodfloors, Jul 23, 2016.
  1. Jlwoodfloors
    Apr 2, 2016
    17
    I'm working in a small space and trying to pulse a micro vibration unit kind of like a hea
  2. Jlwoodfloors
    Apr 2, 2016
    17
    A heartbeat. Thanks for all your help
  3. shortbus
    Sep 30, 2009
    4,096
    1,692
    If your heartbeat is vibrating, you should get to an emergency room quick.
  4. SLK001
    Nov 29, 2011
    852
    243
    Define "small space".
    Define "micro vibration unit".
    Define "why".
    And, I second if your heartbeat is vibrating, you should get help.
    shortbus likes this.
  5. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
  6. Jlwoodfloors
    Apr 2, 2016
    17
    1x1x2 there are batteries, charger ,rf switch, vibration unit and voltage booster . Cell phone vibration unit 3v
  7. GopherT
    Nov 23, 2012
    6,319
    4,043
    1x1x3 cm, inches, furlongs...
  8. Alec_t
    Sep 17, 2013
    5,977
    1,136
    What voltage?
  9. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    Do you want the full double-pulse cadence of a human heartbeat?
    ak
  10. Jlwoodfloors
    Apr 2, 2016
    17
    No just to pulse
  11. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    So a single short pulse at about the same rate as a human heartbeat?
    Does it need to be adjustable?
    ak
  12. Jlwoodfloors
    Apr 2, 2016
    17
    No
  13. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    A CMOS Schmitt trigger hex inverter (40106) can be used to form two monostables in a ring. One is the delay between pulses, and one is the pulse on time that drives a small transistor tnat drives the motor.
    Or, a single hex inverter stage can do it with an extra diode and resistor.
    You still have not said what the battery voltage range is, so a CMOS 555 might not work.
    ak
  14. Jlwoodfloors
    Apr 2, 2016
    17
    I have a 3.7v boosted to 5v
  15. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Is this some kind of random word association test?
    Sinus23, Sensacell and cmartinez like this.
  16. Bernard
    Aug 7, 2008
    4,240
    414
    I would use 3.7 V for vibrator & 5 V for 7555, 8 DIP or SM. Use pots for selecting times then sub. with fixed values. Do you know current draw of vibrator ?
  17. Jlwoodfloors
    Apr 2, 2016
    17
    I believe it is 3v
  18. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    Current drawn when operating, not the voltage rating...
    If you have 5 V for the logic, then you can use a 74AC14. Great part, love the AC (advanced CMOS, not alternating current) output stage. One section as the asymmetrical square wave oscillator (or two if you want more adjustability), and all remaining sections in parallel to drive the vibrator. A CMOS LMC7555 will do the same thing, but where's the fun in that?
    ak
    Bernard likes this.
  19. Bernard
    Aug 7, 2008
    4,240
    414
    I believe the output of 74AC XXX is about 3 mA @ Vdd 5 V.
    My little vibrating motor draws about 100 mA.
  20. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    20 mA source or sink. HC is 3-4 mA.
    ak
    Bernard likes this.
