Need to make an electronic Timer
Discussion in 'The Projects Forum' started by JasonP, Oct 19, 2009.
  1. JasonP
    Oct 9, 2009
    13
    Hi All,
    I need to create an electronic timer that will run off 5 / 12v DC.
    It needs to be much like those mains timers you get to switch lights on and off at a set time. I don't need granularity of days and weeks, just minutes and hours.
    Can someone point in the direction of a kit that is out there that I can make or of a design that I can throw together.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Perhaps a micro controller could be something. I will also not recommend using any hobbyist device connected to the mains without constant supervision. If you are a beginner do not do it at all.
  3. JasonP
    Oct 9, 2009
    13
    It won't be connected to the mains. I need it to run off 5 / 12v DC supply, to control a circuit up to 24v DC.
  4. Bernard
    Aug 7, 2008
    4,233
    414
    If you do not need to change settings often, an 11 stage stright binary counter on a socket strip, with a 555 clock works well. If 5 min. resolution is sufficient, number of stages can be reduced to 9, still to many for 4060 so go with 4040, 12 stage. decoded time sets a flip-flop, which turns on a solid state relay; off decoded time resets flip-flop. Decoded 24 hour resets counter.
  5. JasonP
    Oct 9, 2009
    13
    Any schematics you put in the direction of ?
  6. Bernard
    Aug 7, 2008
    4,233
    414
    How fine do you need the minutes, 1, 5 , 10 or 15 ?? Do you want seperate decoding for min. & hours ??
  7. JasonP
    Oct 9, 2009
    13
    A 1 hour timing would be fine
  8. Bernard
    Aug 7, 2008
    4,233
    414
    One of 24 hours it is. Relay selected will determine transistor & R3, may want to use a darlington tran.May be better gate selection ,but had pin-outs of these at fingertips. I'll be back Friday, got to go now.
  9. Bernard
    Aug 7, 2008
    4,233
    414
    For just hours, this would make programing easy, for ON , one from 1-6 h, one from 1-4 of group of 6h.Kind'a like Navy 4 hour watches, but 6 h watches instead. Switches for reset & time set. Could add led's to outputs, see Bill Marsdens blog on chasers.
