looking to pump out my new r.o. unit into my aquarium using a standard bilge pump i will purchase at the marina . the battery weight is critical in this project. the standard pump are wired for 12 volts to work in boats i hoped to use 2 lantern batteries to run it approximately 15 minutes a month to lift the water approximately 5 feet from the floor to top of aquarium (30) gallions or so. cost is also a determining factor. pumps run 20 or so and two batteries...cheap enough for me. if it works, wire size? where can i put a switch?
